Bluetooth keyboard
Flid72
Member
Bluetooth keyboard
Hi all,
Can someone please suggest a suitable miniature Bluetooth keyboard that can be used in conjunction with a Bravia 4k TV (KD-65XG8796)?
Many thanks Mark.
2 REPLIES 2
Peter_S.
Genius
Hi Mark,
I would recommend the Logitech K400+ keyboard. It works like a charm (using it on my TV as well).
Unfortunately you cannot connect it to your TV directly via Bluetooth but it comes with a dongle that needs to be plugged into a USB port of your TV.
See also:
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-65xg8796/artic...
Cheers
Peter
Flid72
Member
Thank you for your time Peter. I will take a look at that.
