Hi everyone,
I recently purchased the above named camera, love it as I expected but I can't find the setting for bulb. I've been into the manual settings, turned the control wheel as instructed but there is no bulb indicator. Anyone able to advise?
Thanks in advance.
Solved! Go to Solution.
Hi Phil,
Is your camera probably set to one of those modes?
You cannot set the shutter speed to [BULB] in the following situations:
Cheers
PD
Hi Phil,
Cheers
PD
Guys,
Thank you very much for your help, I checked all the settings, adjusted as advised and, hey presto!!, BULB in all it's glory.
I look forward to sunrises, sunsets, fireworks etc etc,
Thanks again,
Phil.
