CDX GT35U
Monkeyboy1
New
CDX GT35U
I have just put one of these in my wives merc the issue is it powers on but just keeps showing the demo .Tried things that I found on you tube but does correct the fault. Any ideas would be great .
1 REPLY 1
TheMaze
Hey @Monkeyboy1
You can cancel the demonstration display which appears during turning off.
1 Press and hold the select button. The setup display appears.
2 Press the select button repeatedly until “DEMO” appears.
3 Rotate the control dial to select “DEMO-OFF.”
4 Press and hold the select button.
The setup is complete, and the display returns to normal reception/play mode.
