kies application
SOLVED
profile.country.en_GB.title
sangomajul
Visitor
kies application
is kies app compatible with sony??
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Watashiwateshdes
Contributor
Kies is made specifically for Samsung devices. The software is designed to recognise their devices only so most likely will not function with any other brand.
Hope that helps
2 REPLIES 2
Watashiwateshdes
Contributor
Hope that helps
Regards
