Login Issues - My Sony
SOLVED
Anonymous
Not applicable
Dear All
Sony is aware of an issue with the MySony login page, which means you also cannot log into these forums.  Sony would like to extend their appologies to this unforseen downtime.  Unfortunately it is unknown when this will be resolved.
If you are subscribed to any threads and you get an email, you can reply via email which 'should' post onto these forums.
If you need to contact Sony Support for assistance, please do so:
Email/Phone : http://services.sony.co.uk/supportmvc/en/Contact/Email
Twitter : https://twitter.com/SonyUK
Thank you for your patience
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi All
As everyone can tell, appears to be resolved as of early this morning.
Cheers
1 REPLY 1
Anonymous
Not applicable
Hi All
Cheers
