Naming HDMI inputs
SOLVED
Naming HDMI inputs
S have a UK Sony TV model KDL-40HX803 I am trying to find out how you name the HDMI inputs. Sony have told me that it is not possible but when I had the TV installed the installer named 3 of these inputs so I know it can be done I just cannot find how to do it.
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
The only way that I know is if you give the input a "label"
  1. Press the [Home] Button on the remote control
  2. Goto "Settings"
  3. Goto "External Inputs"
  4. Goto "AV Presets"
  5. Use the arrow keys on the remote to go across to "Label" and press [OK] - Give it a name
Hope this helps
Cheers
1 REPLY 1
Anonymous
Not applicable
Hi there
  2. Goto "Settings"
Hope this helps
Cheers
