Hi,
I would like to know what is the name of the portable music player, used by (character played by) Liam Neeson in the movie Taken 1, to record? and play sound (and I presume music). I attach a capture, from the movie, of the device. I need the name and where I might find one like this or similar. It needs to be portable and have such small loudspeakers. I searched frantically the internet for it and I could not find it. I would very much appreciate the help.
Thank you
Jolinar
Solved! Go to Solution.
Hi JolinarEdelweiss,
Welcome to the Sony User Community Forum..
I believe this is the product you are looking for SRS-T80 Travel speakers..
I am not sure if you can buy them from Sony anymore but try searching the the net you may get lucky..
You're welcome..
If Sony do not offer an alternative you may also find one on eBay or something similar..
Hi,
Thank you very much, Thalamus. I, already sent an e-mail to Sony to ask if they have a replacement which they still manufacture. Something similar to this.
Thanks again.
Kind regards,
Jolinar
