Hello Everybody, I'm new here and I need urgently help.................
I've got a gift of a Videorecorder, see above, and I 've been buying a remote control on ebay see also above...........
and I'm desperate as I can only engage the time setting and date , but CANNOT ENABLE to start the recorder moving, not starting the tape playing, not rewind, no wimding forward , nore do the loudness, chanel settings, time tracking of the internal clock with the outer time.....NOTHING.............
I've got a poor instruction schedule from the seller :
http://www.gbs-elettronica.it/pdf/manual/3082m.pdf
AND NO OTHER ADVICES OR USER'S MANUAL NEITHER FROM THE SELLER OR, THER IS NOONE IN THE WEB OR ANY
CUSTOMER'S SUPPORT to give the suitable advices NIENTE, NOTHING, NADA, IT'S A SCHAME !!!!!!!!!!!!
It's possible to start the recorder moving with the button on itself, but NOT ON THIS DAMMNED REMOTE CONTROL
Is it probably onlý suited to work with a newer i.e DVD-Player or LCD- TV ?????
The picture when started is not good, have I to clean the heads with some alcohol, or are there out ther some
special cleaning casettes to buy to put them in and do their job successfully
Please HELPP ME !!!!!!! If not, I'll get crazy, and smash all those fu**ing gear against the wall............
Cheers,
Christian
Hi @megavoice, to be able to follow the instructions in the manual you need to use the correct remote control. The compatible remote control for the SLV-SE10AE1 is the (RMT-V256) Part Number: 141800711. I'm not pretty sure if you will be able to find it due to the seniority of the device, but you can check in this website it is the authorised retailer for Sony spare parts: https://www.youritdelivered.com/ You can also contact them directly on +44 (0) 1932 226677, or by email at customerservices@youritdelivered.com
