where to ask question
SOLVED
vonstabber
Member
hi sorry for posting here but i need help with my a77ii camera. where do i post to ask my question. i have found the camera section but cant see how to post a new question. sorry if im being dense 🙂
1 ACCEPTED SOLUTION
Accepted Solutions
jumpsuit
Hi @vonstabber :slight_smile:
Don't worry, it can sometimes take a little while to get used to the forum.
If you click into the Alpha section in  ;Cameras and Camcorders; from the forum home page:
you will see 'New Message ' on the left hand side.
Click that and you'll be able to create a new message :slight_smile:
Cheers
2 REPLIES 2
jumpsuit
Cheers
alexmary.martin
Explorer
Completely agree. Ama having the same navigating problem. Can see where to send a private message but not where to post on a forum. Giving up!!
