This is a 1970's system and I am having problems assembling as the platter when put on centre spindle drops so far it rubs on the base, an E clip is in list of parts , where does it fit and will it solve the problem. I would appreciate any help.
Hi,
Can you maybe share a picture?
Cheers
Peter
Hi Peter S, did you receive the photos.
Hey @pagey65,
Try adding another post and attach the picture instead of sending it privately, so others can take a look and help ^^
- JD
Hi Pagey65
Did you ever resolve your issue with the E clip. I have the same issue
Steve
