I'm having issue's getting TRUEHD Audio passthrough via HDMI to my AV Receiver. Works fine via Blu-ray discs but not via DLNA. I didn't have this issue with my previous players (4200/490)
My AV Receiver shows LPCM instead of TRUEHD.
Anyone know what is causing this?
Hi,
Firstly it would be helpful to know what AV Receiver you're using, we can try and help once we have this information.
If you have already found a solution perhaps sharing it with this community would help others with the same question.
@zaim7890 wrote:I'm having issue's getting TRUEHD Audio passthrough via HDMI to my AV Receiver. Works fine via Blu-ray discs but not via DLNA. I didn't have this issue with my previous players (4200/490)
Hi Zaim,
Sorry for so many questions but can you be more specific about what you are trying to do exactly?
Are you trying to stream audio from another device, i.e. PC, Laptop?
If so what software are you using? iTunes, WMP or some other programme?
Hi there
Try setting "BD Audio Mix Setting" to OFF and see if that makes any difference?
Cheers
PS: Editted
Thanks for stepping in here Quinnicus, I'm not familiar with these products.
