Connecting USB drive to HT-NT5
ProJules
Explorer
I have a drive with a lot of HiRes Flac music files on it.
When I connect it I see this on my TV screen
USB device
* Music file path: USB device
* Photo
But if I select music I get an error message saying "there are no playable contents of this category in this folder"
but the drive is full of music
I tried loading a 96 k 24b it flac file onto a portabe USB stick and trying that also but I got the same message.
1 REPLY 1
Anonymous
Not applicable
Hi there
Flac is a supported filesytem on the HT-NT5 - so unsure exactly why its saying that.  Im assuming that its correctly formatted in either FAT32, NTFS or exFAT?
The system can recognize the following files or folders in USB devices:
– up to folders in the 9th layer (including the root folder)
– up to 500 files/folders in a single lay
Can you try adding a simple everyday MP3 file onto the USB drive.  Basically just to test the USB drive is 'reading' whats on it.  Also try a couple of flacs on another USB drive.
Cheers
