SVR HDT500 USELESS if I can't play HD recordings from external drive
profile.country.EE.title
Monty969
New
Hi
I would like to be able to play HD recordings (backed-up to external harddrive) but have no evidence to show that it is possible when my SVR HDT500 dies (eventually).
The operating instructions suggest that I can only play them on the same machine. This is obviously pointless when the machine is dead.
[Operating instructions: page 31:-
The titles recorded on this recorder are compliant with the XFS file system and can be played on this recorder only.
I have been in touch with "support" twice. The first rep said it was possible the second said it wasn't guaranteed.
So, my question:-
Have you managed to play HD recordings on external harddrive through any device other than the original recorder?
Cheers
Tags (1)
1 REPLY 1
cass_n
Hi @Monty969 and welcome to the community,
I have checked this for you and found out that recordings can only be played on the original recorder due to copyright protection I'm afraid.
Cheers,
C
