FAQ: Web Browser on 2014 Bravia TVs
Anonymous
Not applicable
27,552  Views
The following instructions describe how find the web browser on your 2014 TV, as well as how to access the browser quicker the next time.
1 - Press the [HOME] button on your remote control and go to the Apps menu:
2 - Click on the "All Apps" button in the Applications screen and then scroll all the way to the end of the applications list.  NOTE: There are a lot of apps, so keep scrolling across until you cannot move any further.
3 - At the end, you should see a round blue icon with the letters "WWW" written on it.  Select this icon, as this is the web browser.  A menu will then be displayed with the following two options "Open" or "Add to My Apps".  Choose "Add to My Apps"
4 - The Web Browser is now added to you "My Apps" screen in the applications area.  You can then access the browser much quicker next time around.
3 Comments
