Hi,
I bought xperia L recently and updated to 4.2.2 and expereincing serious battery drain.
Previously i was uisng xperia Miro and satisfied with the battery performance.
But in xperia L batttery is getting drain and i am not using phone fully and once in a day i need to charge 2times to keep my xperia L alive.
My usage will be of chatting in watss app and facebook that to not continuosly, please if any one faced this problem help me out.
Happens the same to me, less than a day with 0 use of the phone all shut down and the phone drains the battery.
I was sleeping and the phone went from 100% to 0% in less than 11h.
This is with 0 use of the phone and you can check 0% screen usage:
Looks like the "telephone" or the "signal" is draining too much battery.
Have no app on and all synch off.
Also if I put it in the pocket the phone starts heating up.
Hi,
As of stopping the app do you notice any stability in battery drain?
Please let me know as i am still facing battery drain problem.
Solved it doing a software repair with Sony PC Companion.
Now I can use the Phone days without recharging.
After the battery reaches 100%(and you get in settings-about phone the message full charged),you can safely remove the charger.
If you are using battery savers,task killers,just remove them.Also,you could try a software repair via sony update service.
