I NEED HELP AS SOON AS POSSIBLE !!!!!!
I KEPT MY PHONE FOR CHARGING AND AFTER FEW HOURS THE BATTERY % STILL REAMAINS D SAME AND I HAVE NEVER SEEN MY BATTERY ABOVE 15 % !!
Solved! Go to Solution.
I am giving you solutions,hopefully if you repair via sony update service it should be fine:
http://www.sonymobile.com/gb/tools/update-service/
is it because of some hardware problem ?
its already in the latest update
After SUS checks your version,it should let you repair.
mine was updated to the latest
no...you should not update..you must repair...even you updated to last firmware you have repair option
ok
there is no repair option
there is no factory reset
