Friends i would like to know whethet xperia L supports USB OTG...? pls reply
Solved! Go to Solution.
127 posts since
Jun 12, 2013
Xperia L does not support USB-OTG. However some models support the USB-host standard (like Xperia S), which allows you to connect USB devices to your phone via a USB Host cable/adapter.
I just tested this with the Xperia L and it didn't seem to work.
What are your thoughts about this forum? Let us know by doing this shortsurvey.
5 posts since
Jun 13, 2013
Will support be added soon?
its basic part of android since ice to have usb otg
127 posts since
Jun 12, 2013
I haven't heard about any plans to change this anytime soon.
Do not say that OTG will not work at all! Xperia M yes, and Xperia L have not?
Yeah my bro's Xperia M could do OTG. The Xperia L sadly cannot, apparantly due to power issues it is disabled. There is a work around which is not much 'on the go'. Hopefully Sony implement it in the future.
I did it for myself to solve this.
XPERIA L + OTG cable -> USB HUB + FLASH DISC <- EXTERNAL BATTERY
It is functional but impractical.
SONY please do something with OTG support for XL.
The definite you can, when you want.
Thanks
and this?
I'll always remember what he forgot in the production of Xperia L and the OTG support.
Let him see what he did.:smileycry:
