Facebeook messenger wont show conversations
Donb
7 ODPOW. 7
Uliwooly
@Donb
Which Xperia do you have? android version? messenger version? have you uninstall and reinstall the app?
Donb
I have xperia L1 and messenger 4.0..yeah u have its showing everything else but the conversation page its just showing a Blue loading icon can u help?? Slightly_frowning_Face
Uliwooly
@Donb
Since that's a third party app, there's not much people can suggest, if it's a bug, it will be up to facebook developer to fix
Donb
Is there anyway to do contact facebook in order to fix it do u no? The woman said it happened on the xperis ax and if I could try find somebody with that fone and try the same solution on this one
Uliwooly
@Donb
if you go to the playstore > type facebook > tap on facebook > scroll down > you will see the contact info there
Donb
Thank You so much 😃
Uliwooly
@Donb
Don't create duplicate posts, you already have an answer.
