Flashlight is locked
profile.country.RU.title
tomatojam
Member
Another topic from me.
After restarting the phone, the flashlight icon in status bar is grayed out. So I can't turn on the torch until I go to a camera app or "testing" in "support" and turn on the flashlight there. Same behavior in the SAFE MODE. (Xperia L3). Look to the right: different colors (dark and light grey)
4 REPLIES 4
profile.country.RO.title
_alexdon_
@tomatojam  does the same happen if you restart your phone? If yes, I would also recommend safe mode.
alexdon
tomatojam
Member
@_alexdon_ did you read OP-post?
It appers only AFTER restarting
_alexdon_
@tomatojam sorry, I misread, I understood resetting.
I will try to escalate this.
alexdon
jan.cifka
New
I have exactly the same problem, but only since yesterday.
Before , everything worked fine
