Need help.
SOLVED
ishanbhatnagar9
Visitor
Need help.
So i got my new xperia L yesterday and as soon as i plugged it to my PC, the Sony PC companion detected that a new software is available. I don't know if i should update it. I don't want to harm my new device in any way. As it does not show what the update is, I don't wanna do it.
1)Should i update it or not? (see screen-shot)
2)Also, is there any way to download game data to SD-card rather than internal storage? Games like NFS MW, GTA III, MC 2,3,4 are huge games and their data is not less than 1 gig. How to move them to SD-card? Please help with this issue!
3)Another issue is that the Album app dosen't work properly. As soon as i open it, it dosen't show anything. Just a black screen with Album written on top.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
1) an update should not damage your phone
2) you can not move apps/games to your SD card
3) settings > apps > all > album > clear everything > restart your phone
Don't forget to mark the Correct Answers & Helpful Answers
3 REPLIES 3
Uliwooly
Uliwooly
this might come handy
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Uliwooly
RickardSonyXperiasupportteam
884 posts since
Jan 12, 2012
1. Apr 18, 2013 5:16 AM (in response to greggmancan)
The external SD-card is only used for media and other files. You can't install apps on the external SD-card. Some apps and games may however have an option to store data on the external SD-card but that is an option inside that game/app in that case.
this should also explain Memory
http://talk.sonymobile.com/message/406527#406527
