Hi,
I have had a couple of issues with my Xperia L, sometimes the alarm doesn't sound or only sounds as vibrate when it is set to sound even if on silent.
Second, there is a tiny red light above the screen on the top left hand side next to the "selfie" camera, is there a reason for this to be on? Someone told me that it is possible to hack into someone's phone and film them from their camera. It sounds a bit far fetched but.... what is this red light for please.
Thanks.
That's the proximity sensor and ambient light sensor
http://support.sonymobile.com/global-en/xperial/userguide/Phone-overview---C2104C2105/
Thanks, that was a quick response.
Anytime
