SD card unmounting issue
KotoriRose
Visitor
Since the last update, my L1 keeps saying SD card unexpectedly removed when the card is still in place and hasn't been removed. Is there anyway I can get it to work proper again?
2 REPLIES 2
Hyperactivedog
Visitor
Got the same issue
Amilii
Visitor
Hi, you can fix the issue by unmounting and mounting SD Card, here are the steps:
Step1: Go to Settings and then to Storage.
Step2: Select the Unmount SD Card option from the Storage tab and then click OK to confirm.
Step3: After this, switch off your phone/device, remove the SD Card, wait for a while and then again put it back to the device.
Step4: Now, switch on your device and navigate to Settings and then Storage.
Step5: Select the Mount SD Card option, which will be displayed only when the card is unmounted.
Or you can format your card to have a try, but before doing so, you must make makeup in advance to avoid data loss, or you can just download the program Bitwar Data Recovery tool, I think it's a good one.
Hope it can help you anyway.
