When I try backing up my Smartphone L1 to Google I get an error message saying 'This browser or app may not be secure. Try using a different browser. If you're already using a supported browser, you can try again to sign in'. Would it be worth updating Xperia companion, and if so how?
I have deleted this account, since this is the one that's causing the difficulties, and now backup and restore is trying to sign into the new account.
Still won't connect to the new account.
Hi @Thomas301, what exactly happens when you try to sign in to the new account? Can you see it as a registered account in the settings?
Error message when trying to connect to my Google account from Back Up and Restore
Error message when trying to connect to my new Google account from Back Up And Restore.
I can see it in accounts and settings.
@Thomas301, is the internet working properly on your phone? Have you tried connecting your phone to a different internet network and checking again?
The Internet works fine. How do I connect my phone to a different network?.
You can go to settings- Wi-Fi- then select the name of the network that you want to connect to, and then it will ask you for the password.
Also, can you make sure that the Google account registered has free space on it or not?
In settings-network how do I select the name of the network that I want to connect to, and how do I check if my google account has enough space or not?.
