Hi guys, Can you help me to my problem?
Why my xperia L randomly restart after 30 minutes of playing game or using wifi or when it gets heat?
Solved! Go to Solution.
If it's switching off because of heat or it's getting to hot then this is a safety feature normally built into all this computer related just like a computer - When it gets to hot or it gets to a pre determined temperature that is deemed the limit of safe running it will shut down to protect itself from permanent damage however on a Pc you may be able to change the temperature some may call it overclocking but phones etc can't be amended as there are no fans to cool it down
Thanks for the help thommo.
What can i do to prevent that? what are the solutions?
You should not use the phone so intensely if you see it getting hot,avoid keeping phone features like wifi,data,bt on all the time.
Is your right to use the phone intensivily as much as you want without problem.
if you want the phone that not restart every 30 minutes buy another brand. or go to fix this....it is not normal.
I have an Xperia L and it was crashing every 15 minutes which made the phone virtually unusable.
I found out by trial and error that it was caused by an incompatibility with the BBC Weather application.
If I clear the cache and uninstalled the application the phone would not crash anymore.
Hope this helps
thank you for your advise guys i already notice the main cause of this. Everytime i use facebook i'ts always restarting after 30 minutes. I already reset the phone, clear cahe and data of the facebook app and it's finally work again.
Thank you Sony for its developers who take care of and debugged firmware. Love @ NEONYM
@alexdon: So stupid response I expect from someone who is disguised as expert?!
I've known better phone not to use at all!
No,I do not think it is stupid at all.And I am not disguised as anything.I suggested him a way to take good care of his phone.Of course you can use the phone until it is "on fire",but after that it is your responsibility only.
