please help me out
Solved! Go to Solution.
I can't answer that question, you have to contact Sony if its a hardware issue, but before you even start considering that, try my suggestions
can you play music through the loud speaker?
you can also repair your phone with
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
no sound man through loud speaker.
test your phone with the suggestions above and/or repair your phone if the problem continue then its a hardware issue, you will have to take it back to the store or a sony repair center
As its less than a month,will sony give me a replacement if there is any hardware issue ?...
yes m trying that... thanks
There might be a loose connection issu. I also had that. I just covered my phone with soft jelly pouch and hitted the speaker area softly with wooden door. That problem solved!!!
