xperia L sound issues
tabish13
Album Not Displaying, Now no sound for calls and music also can anyone help out not even one month completed for purchase
please help me out
23 ODPOW. 23
Mohammed_Althaf
Please sign a petition so that we can send it to sony for the KITKAT update as Xperia M low end device now has 4.3 frimware update.
http://www.change.org/en-IN/petitions/sony-xperia-l-update-to-android-4-4
Tagi (1)
DidiKay
I don't know the reason of its cause but I have found a solution. Okay, make a call to one of your contact numbers. As soon as the dialing screen appears, activate/click on the loudspeaker button. After that End the call. There you go, it is fixed! :-). Play your music again, the internal speaker will work just fine. Please note that the call does not need to go through to ringing at all. Otherwise there will be a missed call or the person would pick the call by which you would have to explain everything (and make Xperia L a loser:-)). I think you can fix the problem in any way by activating the loudspeaker through other apps like FM Radio, etc., but for me simply making a phone call everytime is more than enough 🙂
kannan9995
how did it work?????????/
Tagi (1)
HighDecibel
Xperia Diagnostics totally helped !! Thanks a lot Slightly_smiling_Face
