Bluetooth microphone doesn't work after Android 6.01 update
Sr59
Hi!
After I updated 6.01 I'm not able to use bluetooth connection in my car for phone calls.
Is this a know problem and will there be a correction for this?
Any proposals what I should do?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Sr59
Hi!
I got this working when I deactivated noise cancellation from the phone. It seems that in a car it will cancel all noise also your speak.
4 ODPOW. 4
Uliwooly
Could you test it in >>> safe mode
Sr59
HI!
Tried that but unfortunately it didn't help. I can make calls and hear the other party but he/she doesn't hear me.
Uliwooly
I've seen other posts similar to this, perhaps if you use the search bar you will find some suggestions.
Sr59
Hi!
