Doubt about Model Number
SOLVED
gokulnath
Visitor
Hey.
I am using Xperia M Single SIM (C1904) and I saw that new 4.3 update was realsed for Xperia M Single SIM but there was showing single SIM Model number is C1905. Can you please explain why showing like that?
1 ACCEPTED SOLUTION
Accepted Solutions
Rickard
Master
The update is being rolled out for both C1904 and C1905 right now. But as usual the update is done gradually for each country and operator and may need local and operator approvals before you can update your phone.
4 REPLIES 4
Rickard
Master
The difference between C1904 and C1905 are what networks they support.
C1904:
UMTS HSPA+ 850 (Band V), 1900 (Band II), 1700 (Band IV), 2100 (Band I) MHz
GSM GPRS/EDGE 850, 900, 1800, 1900 MHz
C1905:
UMTS HSPA+ 900 (Band VIII), 2100 (Band I) MHz
gokulnath
Visitor
Thanks for your reply. So only C1905 got 4.3 update right now? C1904 will get update soon?
Rickard
Master
gokulnath
Visitor
I am from India  and I tried via Sony PC Companion and I cant even find.
I think need more time!
Thanks for your support! Slightly_smiling_Face
