I'm sorry to hear about your experience @ispammee.
In this situation though, your only option will be to contact your local support team again and arrange another repair. I cannot comment on what the process will be, whether they will replace it or not, as different regions will have different processes. You should discuss that with your local support team.
Good luck.
Hey bro same thinks happen with me, after one time service few month letter i take photos under water then i found water vapour in the front and the back camera lenses but the phone was still working. The next day morning when i open my xperia then i shocked that my phone is completely dead. I went to sony service center and told all the incident, i'm again shocked when they said that
these is your fault because we are always say that waterprof mobile are waterprof when all caps are close i say that all caps are close but they don't agree......
removed by alexdon
My sony m4 aqua was waterproof but i used underwater and after notice cameras ( front and back ) were steamed with water vapour, i try opening the camera n snapchat app but it doesnt work as camera has stopped , i dont have warrenty on phone but everything else works , what do i do ?? Pls help me
waterproof or water resistant it's meant for protecting your phone from rain or accidental spills, with that said, you could place the phone in a container with rice for 24 or 48 hrs
you can also contact your Local support
Eventhough the phones is working smoothly, the sd has started to stop then come bqck on but cameras are still off, i will try the rice but dont think itll work, thx tho
Same thing happened to me so I'm just gonna break it. I got a new phone anyway lmao
