No Network Connection
Dillu06
Visitor
Network not getting connected
2 REPLIES 2
Jonas
Master
Hi @Dillu06, sorry to hear that. Slightly_frowning_Face
Is it the mobile network that you don't have a connection to, or is it a Wi-Fi connection that isn't working?
If it is the mobile network connection, does the device recognize your SIM card? You can also try and search for available networks and register yourself manually on your operators network if you go to Settings > More > Mobile networks > Network operators or Service providers (depending on Android version) > Select a network in the list that appears.
Let me know if that helps! Slightly_smiling_Face
NETWORK123
Visitor
Network 0
Network subset 0
Services provider 0
Corporate 0
Sim 0
