Hi Km1961,
Welcome to the community,
When the phone rings, is the ring the same as your Ringtone or completely different?
How did the Safemode go, did the issue occur in this mode?
I have the same problem. It usually rings in the mornings. Same signal as standard ring signal. To make it stop I have to restart the phone.
Sometimes the clock also change size by itself but the phone does not scale so half the clock disappears.
How did you solve thi ringing?
I'm currently experiencing the problem of the phone ringing and no incoming call. What is the fix for this? It wasn't discussed.
My Sony Xperia D6503 will suddenly start ringing incessantly with the same ring as an incoming telephone call. I look at all the possible incoming signals such as incoming call, wake up call, text message, voice mail - everything. This even happened once while the phone was charging. I can find nothing to “answer”, so I turn the phone off. When I restart the phone, it works fine for a few hours, sometimes a few days - but the problem always returns. Does anyone have any idea what is going On?
