Problem with xperia M4 aqua connectivity
yanko
Visitor
When i connect phone to pc via usb, pc doesn't recognize it. Right-clik on icon shows only text Android. In devices and printers i see again device Android, double click shows that this device doesn't have driver. But when i select Install software in phone, phone is then recognized in pc.
Later i installed Xperia companion. When i plug usb both to pc and phone in, i see in companion that phone is locked, text below is 1. unlock required, 2. Allow data access. I don't find neither data access nor Connected devices in settings. In phone i still see option to install xperia companion which is already installed. I still always have to select to install companion (but i don't install it) in order to have phone connected.
I tried with another usb, i wouldn't post this if it worked.
1 REPLY 1
yanko
Visitor
Does it seems that noone has a clue about this?
