hi i have forgotton the pin code to sign onto the phone ,i have tried several resolutions on the internet,going into emergency call mode putting in a string of numbers,,nothing works,does anyone know a fix that works,,,thanks
Hi @xperiam43, welcome to our forum!
There are two ways to remove your screen lock, but in both cases, the device will be reset and all data stored on in the internal storage will be deleted.
You can either reset the device by performing a software repair using Xperia Companion on a computer, or reset the device using the Google service called Find My Device.
To reset the Xperia device using Find My Device
Keep in mind that you may need to verify the ownership of the device with the Google account that is added in your device, so it's important that you have access to this account.
I hope that answers your question!
