Liberar equipo, ya fui a donde lo compre pero el código que me llego dice imbalido..
Free equipment, I went to where I bought it but the code that came to me says invalid .. - GT
Hi @Aniux1020, welcome to our community!
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
What code are you looking for, is it the one to unlock a network lock on your device? This code can only be provided by the operator that locked the device.
Before you enter the code, make sure that you have unlocking attempts left and you can check this if you open up the application called "Phone" > use the dial pad to type in *#*#7378423#*#* > Service info > SIM lock. Check the number to the right of where it says [X] Network, is this at 0?
Let me know how it goes!
Hey,
I have tried to unlock with my imei but i'ts not working. Do you have another tip?
Greetings
Hi @Mothejo, welcome to our forum!
The IMEI is not the code you should enter. The code that you should enter to remove a network lock is called NUC (Network unlocking code). It's 16 digits and can only be provided by your operator.
Please see my previous post on the link below, just to make sure that you have unlocking attempts left.
/t5/Xperia-M4-Aqua/Unlock-code/m-p/1389922#M13809
Let me know if that helps!
