I have a problem when I connect the headphones, with any movement they get out of the connector.
Can somebody help me
Tengo un problema cuando conecto los auriculares, con cualquier movimiento se salen del conector.
Alguien me puede ayudar
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
First thing to do is to check if there's anything inside the 3.5mm port, if not then test a different pair of headphones.
