Adding Ringtones under ICS
SOLVED
CKRedwing
Visitor
Hi all,
I just updated to ICS and want to change my ringtone for incoming calls.  I just added a mp3 to my sdcard, but I am unable to figure how to make it my ringtone.  I have tried in settings, and under music player.  Any help will be appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
CKRedwing
Visitor
Thanks for the help... although both of the options you provided were unavailable on my Ion (at least as far as I could tell)  I did stumble on in the settings>sound>phone ringtone;  that the title of it is Sound Picker, and if you click on the music note in the upper right corner, you can select what library to look in.  From there I was able to pick my ringtone.
3 REPLIES 3
aravindad
Visitor
Dear CKRedwing,
go to music player > option > you'l find " Set as Rington"
or
settings > sound > phone rington > scroll down and select MUSIC LIBRARY > " choose your fav song " as ringtone.
HOPE IT WILL HELP  Dizzy_Face
:smileygrin:
Legend
  • Correct Answers - 30 points
  • Helpful Answers - 10 points
CKRedwing
Visitor
aravindad
Visitor
HMM. OKI.. thanks for sharing..
