Hi,
My new Xperia V have recurring problems with MMS.
I have a new Telia SIM card, Telia in Sweden has checked it and MMS is enabled. ANd it has worked, once in a while...
First, problems started after installing Go sms pro. I uninstalled the app, and in the end I had to do the repair through PC companion,
then I got MMS to work again.
Visited Croatia a couple of days ago. After I got back, MMS does no longer work. Again...
Deleted the APN:s, instaled them again, deleted the messag app's data, no improvement.
Anyone have any ideas? Can't have it like needing to do the repair in PC companion every other week...
/ B R,
Patrik
Solved! Go to Solution.
you could repair your phone once more with SUS just to narrow down the issue, also go to settings > about phone > status > how good is your coverage ?
repair your phone with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
do you have any taskiller task managers or antivirus? it might be a faulty sim card, I will also tell your carrier/network to send you the APN OTA
SIM card is new, problem was there already with the previous one.
APN:s are correct. It has as I said been working.
I have no task managers or antivrius. Any recommendations?
well I would contact your carrier to send you the APN settings OTA
OK, I did. APN installed from Telia OTA. No improvement...
did you contacted your carrier or settings > xperia > etc ?
I got the settings sent to me from the carrier.
This is so weird. And tiring.
Bridge (for Mac)
-91 dBm 52 asu regarding coverage.
And sure, I can repair again and it might work.
But for how long? Last time it lasted for a week.
And what "breaks2 it?
Not too convenient to reinstall everything once again either.
do you have stamina mode on?
