Cannot copy file from pc to xperia
SOLVED
morris108
Visitor
I can copy a file from the micro sd card to the computer no problem
I have applications/developmentUSB debugging ticked on.
The micro sd card has no way of being locked, does it?
I have simply connected the usb cable from the computer to the mini pro.
Have no other problems in the usb connectivity, pc companion asks if it should be launched - and I successfully installed an update.
When trying to paste a file - I get the following error: "The device has either stopped responding or has been disconnected"
Please help - if you can
1 ACCEPTED SOLUTION
Accepted Solutions
Mr_Lu
Visitor
firstly, have you tried to change another USB port to connect or change a computer to check it is the fault on your pc? btw, have you tried to use MSC connection mode?
7 REPLIES 7
Mr_Lu
Visitor
morris108
Visitor
In fact - when I connect - it says "Media transfer mode"
I will not be back at the computer for a few hours - but I will then investigate what MSC mode is.
Thank You
slimshaddy
Hero
there are two modes
  1. media transfer mode
  2. mass storage ( msc )
morris108
Visitor
That was it - Just have to connect in MSC mode - I had no idea....
morris108
Visitor
MSC mode was the answer
slimshaddy
Hero
Hmm Winking_Face
starchaser
Visitor
Maybe a stupid question.. but how you connect the phone in MSC mode? :smileyblush:
I have the same issue with Xperia S. When connected via USB to PC, i can see the phone memory in windows explorer, but i can not open any file (photos, music, pdf etc). i can see the files and folders, but i can not copy anything to pc or from pc to xperia.
It says that  "The device has either stopped responding or has been disconnected".
PC companion works fine, btw
Thank you!
