Hi,
How can I go about changing the language of an xperia x10 mini to English ( US). I got this phone from Denmark.
Please help!!!Thanks much.
Mackis
Solved! Go to Solution.
Hi Mackis,
To change the language to English, from the menu screen, tap on Settings (the icon with the tools) then slide the screen to the eleventh option and tap on it, once there, tap the first option that appears and by sliding the screen up and down, you should see and tap on English (United States) .
Hi Mackis,
Hi Annie,
Thanks much for your help.I worked and your amazing!
Don't mention it Mackis, we are here to help you.
thanks, but how do I change between languages when texting? this used to be a button on the keyboard, which has gone with the lateset update...?
