Couldn't find Stock ROM/Firmware
SOLVED
umiteks
Visitor
Dear friends,
I am looking for one day but no result.
I have wiped all my system after root, as a custom from my old CM ROM days, accidentaly.
Now I need to find any;
Stock ROM (firmware) of: Xperia Arc S LT18i - SI 1254-9037 (SA)
but, I couldn't. There are some  other distributions but not for SI 1254-9037.
Isn't there an link of official source from Sony?
Could you advise me please?
Thank you in advance,
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you need to relock your bootloader and flash Sony's firmware so you can use SUS or PCC
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
7 REPLIES 7
Uliwooly
the best thing to do is to search the XDA Forum
or use a global generic firmware
http://talk.sonymobile.com/thread/38251
umiteks
Visitor
Thank you Sir
I just couldn't be sure if any mallfunction may ocur when I flash a generic one.
1254-9037 is what write on the back of phone.
But as I understand, it won't create any problem, right?
Thank you...
Uliwooly
it shouldn't create issues
umiteks
Visitor
Another reason
When I use Sony Update Service, it warns:
"Because your phone has a changed software, software couldn't be changed"
Same also, when I try Phone repair on PC Companion: error 2003
Uliwooly
umiteks
Visitor
Oh
I got it now! Sorry Dizzy_Face
I Found an explanation:
What the different of this one...
(1254-2716). Generic Global or Specific region I don't know.
As a System no differences ,but as for ME & North Africa there's some Add-Ons
Like Arabic R/W ,SlideME market (google play doesn't work in every country ,e.g :my country) ,and other Things
SI numbers are different from region to other I guess the FW you pointed to is US region
any way I just wanted to share it ,I don't own the device ,mine is SK17i
May be useful for searching same topic...
Thank you again
Uliwooly
the SI numbers are different in regions and even in the same country
you can flash the SK17i or SK17a to your phone, it won't affect it
