data traffic notification pop up problem
SOLVED
sn7495
Visitor
I was using xperia sola with ICS.It had a problem with data traffic.If data traffic is enabled,then the data traffic notification pop up will come frequently in every 5 or 6 minutes or so..this happens when keeping the phone idle,if we are brwsing internet, problem will not occur.there will b around 10-20 pop ups in every hour.I have reinstalled the software,changed the sim card..but no use.Now i went to sony customer care centre and they downgraded to Andriod 2.3.7...But still the problem exists even worse than before.This is something irritating to press ok for all the pop ups appeared before doing anything with mobile.any way to get rid of this problem.....???
1 ACCEPTED SOLUTION
Accepted Solutions
Samuel1
Hero
This is not a Android/Sony provided function. Most likely it's a push notification from your operator which triggers every time you have finished a GPRS session. As the phone connects every now and then to check for updates you therefor get a message every time it's done.
Contact your operator and check with them.
What are your thoughts about this forum? Let us know by doing this short survey.
3 REPLIES 3
Samuel1
Hero
sn7495
Visitor
thankyou for your reply.it helped
Samuel1
Hero
I'm glad to hear. Let me know if I can be to any further assistance.
