my notification bar has stopped displaying the data traffic signal when enabled. also there is no internet connection detected but phone signal strength is fine ( 5 bars) pls help soon .it has been working ok for a month now .
Solved! Go to Solution.
I agree with Raja22223, you should repair your phone with SUS
also go to
settings > data usage > have you set a limit that perhaps you've reached and it doesn't allow you to user your data plan anymore?
do you have taskillers or antivirus?
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
1st do you have a data plan?
2nd do you have the correct apn settings? (settings > xperia > internet settings)
3rd do you see the 3G or H icon on the notification bar?
4th settings > data usage > mobile data (is it on?)
yes, i have a 2g data plan since last 2 months, it was working fine uptil last night. as of this morning, the data traffic symbol has disappered . it appears when i disable data traffic tho, only not when enabled. i haven't chaged my apn or data usage settings meanwhle, so i can't understand why it has stopped working so suddenly. pls help
If that is the case, Kindly perform the Factory data reset in your mobile and see, Hope this may help You
Mark if found
also go to
thank you so much for your help. its working fine now.
plz tell me what u did to resolve this issue..im faceing the same issue and tried everything I can. Also tried to reinstall the software using SUS but nothing seems to be working..HELP!!!
Reset to factory settings after repairing,it could work.
i once had this problem..what i did was i changed my sim card, i realized that im not using a 3g sim hahaha..
hi, my problem turned out to be because of the isp , vodafone was to blame not xperia .
