Dear Sir,
I am chirag panjwani from Mumbai, India. I am using xperia arc. Today i had some problem with display. Dont know how, suddenly On top of the display on notification bar there is some bar shows some words like this : P: 0 / 1. dx : 380.0, dY: -171 and all... and when i touch screen a horizon and vertical lines appears, when i scrub menu or anything else the line get stuck, the lines are like scratches. Please give me solution as early as possible. Thank you.
Hey there
You must be on ICS right
Go to settings > developer options > unmark pointer locations
Thank u very much Nabeel... Problem Solved.
