hi friends i want to know how to downgrade my neo v from ics to gb without voiding the warranty of my phone
pls guide me step by step
Solved! Go to Solution.
You can manually downgrade but it "could" void your warranty this is how
Xperia Neo V MT11i 2.3.4 update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30938
Don't forget to mark the Correct Answers & Helpful Answers
You need to contact
Sony's Repair Center
http://www.sonymobile.com/gb/support/contact-us/
thank you
Anytime
is there any chances that phone will b in dead state if anything goes wrong?
if something goes wrong just re-start the whole process all over, as long as you DON'T unlock the bootloader you should be fine.
so now im going to downgrade my neo v by flashing it thnx for the help
just follow the steps and watch the videos, it's quite easy.
Hi uliwooly,
Regarding the warranty voiding,my understanding was anything with out unlocking the bootloader is safe?If so ,do you think flasing with flashtool is a safe method?
Also the flashtool I am going to use is 0.7.1.0 but most of your/other posting was menting about the version 0.6.x..Does it makes a difference.
Thank in advance,
