Hey,
Can anyone help please ?
I have an Xperia Play (which I love) on a O2 contract its just three months old and has been kept in a case most of its life but there is alot of dust and stuff under the screen at the bottom and its starting to effect the use of the phone.
Anyone else had this problem ?
I am going to take back to the O2 store tomorrow or can i return it direct to Sony ?
It has a 2 year warranty
thanks in advance
Karmapolice
I suggest getting the handset to a service centre directly as they should be able fix this up for you.
Please use the link below to find the appropriate contact details for Sony Ericsson within your region.
http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
