I Forgot unlock Pin Code and not able to operate my phone.
what can i do to unlock my phone.
Is there any code to reset pin code.
i have windows 8
It will remove the lock.I know you have windows 8 or 8.1,that is why you need to run the program in compatibility mode with windows 7.Do you know how to do that?
then my phone will appear on update service.
yes i can do it with another laptop.
and does the windows 7 need to be in compatiblity mode.
You can run it in compatibility mode with windows 7 from windows 8 too.But do it on a windows 7 laptop.
and can i do it in windows 8 by changing the phone to xperia L in update service.is that possible i only need to remove the pin lock.
Yes,a repair is needed to remove pin lock.You need to select xperia j in the phones,not other.
OK.
thank you for your help.
Anytime.Keep us updated.
sorry but can you tell me how to do it with windows 8.
