I've been using my phone for two days (yes, it's brand new), and I've somehow managed to ruin it.
Problem is, whenever I open the gallery, it shows nothing, it's blank, even though I've taken a few pictures and videos.
Also, I can see the pictures and videos thumbnails from the homescreen, but clicking a picture on it, just causes the phone to open a blank screen.
The videos work fine though, they play from the pane itself.
Is this some bug with the gallery or teh phone?
Is there some way to get around it by making some other app the default image viewer?
if none of the above work then
ok,
1) backup everything
2) repair your phone with Update Service
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
or
let me make it simpler
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
try this app instead
QuickPic
Settings -> applications -> manage applications -> all -> gallery (Clear everything )
make sure to mark the correct & helpful answers
ok try this
settings -> storage -> unmount SD card
turn off the phone -> remove everything, w/o the battery press and hold the power button for 5 seconds. -> put everything back -> settings -> applications -> manage applications -> all -> gallery -> clear everything
try again
ok,
and also
or
How to install it
You need to
or
now on your phone
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
make sure to mark the Correct & Helpful Answers
Thank you, Mr. Uliwooly.
My friend's phone had the same problem, and he did it by backup+update.
Mine, I just updated the software, and now it's working pretty fine 😐
anytime
