Hi everyone,
after deciding to root my xperia pro I found out that I cannot do it with the 4.0.2.a.0.62 firmware. I have an unlocked bootloader so I was wondering if the there is an easy way to gain root access?
If not, I have read that I need to downgrade to 4.0.2.a.0.42 and root with the zerg rush, and then I have to update back to 4.0.2.a.0.62 by using the update center, NOT companion.
Here is my problem, I can't find firmware 4.0.2.a.0.42 all the links I found seem to be broken! someone can provide a link with the official ericsson firmware (I don't want to try custom things since the camera doesn't work very well on those.)
Thank you very much!
Solved! Go to Solution.
you can't root .62 unless you unlock the bootloader (not recommended)
http://talk.sonyericsson.com/thread/29687
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
Hi uliwooly,
thank you for your answer. I found the firmware so I will try to root soon.
I knew I cannot do it under .62 and I had to downgrade :smileyhappy:. Second, I have an unlocked bootloader is it hard to root in this case? I tried to find some instructions to do it but it seemed way too complicated.
Thank you very much,
best wishes!
just out of curiousity, why did you unlocked your bootloader? If I were you I would re-lock the bootloader
I didn't, it was unlocked when I bought it.
Best wishes
was it used? anyway let me know if you need any more help
Hi,
Not at all. I bought it brand new from the my provider. When I go to the service menu it says
unlocked bootloader: YES.
I read that some providers sell the phones with an unlocked bootloader so I thought this wasn't a major issue. I guess it is not that common.
Best wishes, and thanks once again!
that doesn't mean that it's unlocked, it is unlockable
Ahhhhhh,
that makes more sense, sorry for being such a noob. :smileygrin:. Anyway, thank you very much!
I think I succeeded in rooting my phone, now I need to update back to .62 and learn how to uninstall stock apps that I don't want. Any tips in how to do that?
Thank you!
