how can I remove the auto dash (-) in contact number
Nie dotyczy
Hi all
When I enter the mobile number the auto dash ( - ) come automatically after 4 digits
Even when I tried to update number in the contact
why I don’t want it , because when I make a backup , the numbers will be with dash ( E.g. 1111-1111-1111 ) and this format I can’t restore it in another website or software
Any idea of how can remove auto dash?
Thank you
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
suze
Pasjonat
The phone book and its numbers I believe is governed in set up by what language you select when you set up the phone, for example English UK and English US have different phone book number settings (in fact there are 6 or 7 different English settings) so this could be a starting point for you to check.
It is found in Menu>Settings>Language and Keyboard>Locale
6 ODPOW. 6
suze
Pasjonat
Nie dotyczy
Thank you that was a correct solution
I just change it from United State to United Kingdom
suze
Pasjonat
Oh good, glad you got it sorted!
imAQ
Thank you you so much Sir! It really helped me.
imAQ
Really helpful
AB2
this answer is great.
i had this problem several years.
very thank you
