Hi --
I am using xperia neo v ICS 4.0.4, I am unable to send business cards using the send contacts, It always converts the contact to multimedia format. I do not want to send the business card via multimedia, I just need to do it using plain message. How do I do it ? Any help on this will be greatly appreciated.
Solved! Go to Solution.
Hi,
As you are using the Andriod 4.0.4, it's dialer is very laggy as for as I know. So it's better to have a good dialer to use the phone in emergency situations as well as your need to send the contact as a plain text, you can install the app "exDialer" from the play store which will ask you to share the contact as vCard or plain text when u click on the share on any contact
Have a look here:
https://play.google.com/store/apps/details?id=com.modoohut.dialer&hl=en
look for apps that will do so on the play store
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
Hi,
Have a look here:
Thanks the app is good, and it does what I wanted,
